I just moved into a new house, and it’s got a LiteTouch centralized lighting system installed. All of the lights are hardwired back to 3 panels in the basement that contain relay and dimmer modules. There’s a controller that connects to this, and then it has a bunch of keypads around the house that talk back to the controller.
The system was installed in 1994, and whoever lived here before was not gentle when pressing the buttons, most of them are worn out and I cannot turn on some of my lights. New keypads are expensive, and hard to get without paying for an expensive service call. I’m eventually going to rip the system out and replace it with a Centralite Elegance XL system since I can do the Centralite for about $4k. It would cost me close to $10k to upgrade my controller and keypads if I stayed with LiteTouch (now owned by Savant).
So, I’d like to get Vera to integrate with this so I can at least control everything. Has anyone done this? I searched the forum and I didn’t find anything. There’s a serial port on the controller (which is a LiteTouch Standard CCU).
Well, I fixed the keypads. The snap domes under each button were taped on at the factory, and the tape wore out and fell off. The snap domes fell to the bottom of the switch. I redid the tape, and now all of my buttons work.
But, I still want to integrate this with Vera. Does no one have any info on this product at all? I know they aren’t exactly common, but maybe there’s someone here that worked for an installer back in the day and still has some documentation?
It doesn’t appear that there is a way to enumerate all of the loads configured in the unit, so I will probably have to create my switches in vera manually. Does anyone have a template or something that I can use to write a plugin for this?
Apparently, when a switch is pressed, it will report status through the serial port. However, I need to connect a couple of pins together to do this, and I’m not sure of the format of the message when it reports status.
