Integrate device that has a 3 pole rocker switch
I am interested in vera controlling a device that has a hardwired 3 pole rocker switch. Has anyone had experience with this? For my garage door opener I put in a 125VAC/10A DPDT Plug-In Relay from radioshack to switch on when the relay senses power and then I used a Vera controlled outlet to run it, however for this new project the device’s switch has 3 positions (up, off, down) so I don’t think I can use that kind of solution unless I use two relay switches and two vera controlled electrical outlets. Any other solutions that could make this work? Thanks in advance for the assistance!
