[center][/center]
Important last minute notes
Power Adapters: This package includes 2 power adapters. The one with the red and green lights on the back connects to the black battery pack only. The other power adapter, with the black grips on the side, is to connect to Vera.
Green Light: In the enclosed Quick Start Guide it says to look for a green light on the battery pack’s power pack. Ignore this; some of the battery packs will arrive fully charged so the green light will not light up. The green light indicates the battery pack is charging, and it goes out when the battery pack is fully charged.
MIOS Engine: In the documentation whenever it refers to the ‘MIOS Engine’, this means Vera. Vera is the MIOS Engine.
New documentation: Your Vera’s has a new user interface released in January, 2010. The screen shots and wiki on micasaverde.com do not apply. The user’s manual for this new user interface is available at http://micasaverde.com/vera2docs or by clicking any of the help or Quick Start icons in Vera’s web page.
Including or excluding Zwave devices from Vera’s network:
As explained in the online user’s manual, the procedure is:
- Disconnect all of Vera’s cables so you can carry Vera around to the Zwave devices you want to include or exclude, like light switches, door locks, sensors and so on.
- Connect the battery pack to Vera using the short cable supplied and turn the battery pack on. The battery pack can power Vera for up to 2 hours.
- Wait up to 60 seconds for the Zwave light on Vera to light up solid.
3a. To include devices: Tap Vera’s Zwave button. The Zwave light will blink slowly, once per second, to indicate Vera is in include mode.
3b. To exclude or devices: Press and hold Vera’s Zwave button for 3 seconds, then let go. The Zwave light will blink rapidly, 4 times per second, to indicate Vera is in exclude mode. - Carry Vera around to all the devices you want to include or exclude and press each device’s activate button. When Vera has successfully included or excluded a device the Zwave light will flutter for 2 seconds as confirmation.
Note: You can switch between include and exclude mode. If, while in include mode, you hold the Zwave button for 3 seconds and let go, the Zwave light will blink fast to indicate you are now in exclude mode. If, while in exclude mode, you tap the Zwave button, the Zwave light will blink slowly to indicate you are now in include mode.
When you have finished adding or removing devices and want to save your changes, tap the Zwave button once if include mode to exit include mode and go back to normal. When Vera has finished saving the new devices and resumed normal operation the Zwave light will come on solid again. If you’re in exclude mode and want to save your changes, tap the Zwave button once to go into include mode, then, when in include mode, tap it again. When the Zwave light is on solid you can now unplug the battery pack and reconnect Vera like normal.
Troubleshooting: If you have trouble adding or removing a node, then do not unplug the battery pack or turn Vera off. Take Vera, still running on battery power, and connect ETH1 to your home network, like normal. Wait up to 2 minutes for the ETH1 light to come on solid, indicating Vera is connected to the internet. Log in to Vera’s setup page, like normal, and choose from the toolbar Advanced, then Tech Support. Then fill out a trouble ticket. Vera keeps logs while you are including or excluding devices, which logs are sent to our support team when you submit a trouble ticket. But those logs are lost when Vera loses power. So as long as Vera keeps running on battery power, the logs will remain on Vera Once the logs are submitted you can disconnect the battery pack and reconnect Vera to the main power.
