I did buy second Vera now and very happy using it. I try now to connect an insteon USB 2413U with first Vera1 , and the system see the PLM right away as serial ports(?) and I add a X10 on devices, it is ok too but I can not use it.
It is any procedures to add that 2413U and use X10 with it?
Did you ever get the 2413u to work? I have the new Vera and can’t get it to be recognized. Very Frustrating. I’m hoping you figured it out and can share your findings.
