Hi intveltr,
I recently picked up some Insteon items to start integrating Altsteon, and maybe work on the code.
For the most part, dimmers (in KeypadLincs) work fine. The only issue I am having is with the FanLincs. These show up as 3 devices in the Vera UI5 (a parent, child for the light, and child for the fan). The FanLincs replaced by Leviton VRF01s which HomeWave supported as dimmers. When I go to link the HomeWave dimmer to the FanLinc light portion, all is well. However, the “fan” child never appears in HomeWave, so I can’t control it.
Do you have any plans for Insteon/Altsteon support? I am already signed up to betatest HomeWave, so I can help test.
