Installed Telguard GDC1 today. AWESOME!
Installed the Telguard GDC1 today and it was an absolute pleasure! Easy to install, instructions well written and clear, product worked as advertised the first time! Will see how it does over time, but initial response is awesome! Only complaint, mine had some weird plastic things that were supposed to be drywall anchors, but were something I’ve never seen before so I just used ones I had around the house.
Installed mine last weekend. Agree with your assessment, very easy and well done.
What UI are you guys running with this unit? From the research I’ve done today it seems as though UI7 is required…at least for the Linear GD00Z. I upgraded to UI7 tonight, had too m any issues and have already downgraded back to UI5.
You need to give it more then a few min. You’ll never learn its differences or how to use it if you don’t actually give it a chance.
You need to give it more then a few min. You’ll never learn its differences or how to use it if you don’t actually give it a chance.[/quote]
You are probably right. I am going to have to go to it eventually. But I’m not that proficient at all of this and get lost easily. For example, when I went to UI7 my DSC Alarm Panel was no longer connected. So I removed the DSC Plug In and then re-installed it. That fixed the Panel connection problem. But then I had lost Partition 1 with my 6 door/window sensors. And I had no idea how to get those back! So I went back to UI5 for now.
