Vera1 running 1.0.996
Any ideas as to why I can’t download the IR device plugin?
The test commands controlled my device, I selected the device, saved it and now see the device in the assigned room but am waiting for the plugin to download so it can be assigned to the scene.
“Luup: Failed to download all plugins. Will retry in 10 minutes” Its been trying for 2 days now.
.996 was the final release with UI2 from what I remember so it never worked. I opted for CommandFusion to control my A/V gear.
Don’t know if it’s fixed or not but the last I cheked with UI4 it was the still the same error message.
I too am having the same problem. I’ve installed the GCC 100 plugin and sent the appropriate test codes to my television, but am still receiving the error message. Any idea on how to resolve this?
As the problem was specific to Vera 2/UI4 and there has not been any update, it is reasonable to assume this was not rectified and if you desire any resolution, you would need to raise a support ticket to MCV to have them look at it; otherwise, as contained in the other thread, the alternative option would be to upgrade to UI5.
