Info Viewer plugin - Log Viewer updated
Great idea… thanks!
Finally got around to updating to the latest version.
Thanks; very good stuff! 8)
[quote=“gengen, post:66, topic:174138”]Here was Info Viewer 0.58, which fixes several recently reported bugs in 0.57
@oTi@ - Pattern functionality is now working again as expected.
@oTi@ - The new version correctly reports 0.58[/quote]
[quote=“gengen, post:100, topic:174138”]The “Handler failed” message typically happens when the LuaUPnP daemon, which is at the heart of Vera is restarting. This happens in UI5 whenever you press the red “Save” button and you see the “busy” barber pole.
As soon as the log gets fully loaded into your browser, it can handle these momentary interruptions.
BTW: If you use the log window a lot, you may want to copy the URL into a desktop shortcut. This works really well and avoids having to go through the info viewer UI and menu. The URL (for locally connected Veras - both UI5 and UI7) is:
http:///port_3480/data_request?id=lr_al_info&fnc=getLog&app=localapp[/quote]
when I do a reload, I get it back. but it seems to stop at that point in time. refreshing the browser doesn’t help. It’s just stuck and I can’t seen any new logs. so then tried…
… used the shortcut tonight. Saw nothing in IE… so tried Firefox. Just keep getting this message repeated over and over again:
Info Viewer ajax error - possibly malformed XML received: Handler failed
lastly, I put “sonos” in the lua pattern box…and now that seems to be what it wants to show me when it is working. I try to clear it, but it just keeps coming back.
Here is what happened after running the nightly heal. It just never came back.
If I rerun the log page, I just get the handler message. I’ll have to reload again to get it back.
any ideas? makes it really hard to debug something that happens right after reload.
thanks. driving me nuts!
@tomgru,
I’m not sure what your problem is but I suggest getting your log via ssh if all else fails.
There are lots of pointers on this forum and on the wiki on how to do that.
@tomgru,
Your problems are beginning to fit the profile for memory issues. Check in the log for messages like Failed to save user data and similar. If you are running a lot of plugins on a Vera Lite and/or you have a lot of files consuming your flash, it could cause some of your symptoms.
I also once had a rash of Info Viewer ajax error - possibly malformed XML received: Handler failed messages caused by logging to a defective USB stick.
[quote=“RexBeckett, post:106, topic:174138”]@tomgru,
I also once had a rash of Info Viewer ajax error - possibly malformed XML received: Handler failed messages caused by logging to a defective USB stick.[/quote]
Thanks… i’ll check into that. Any idea how i would know if my USB stick is defective?
Screen shot of it setup attached. Also attached some shots of memory usage, not sure what to make of it. Sorry… noob still trying to figure this out!
One other edit… I see this in my logs, but not the other warning you suggested.
LOG_CHECK_MEMORY_LEAK pMem start 0x202e000 now 0x20b0000 last 0x202e000 leaked 532480 <0x2c005680>
You are running very low on memory. I had a Vera Lite that got down to that level. It would restart whenever several things happened at the same time and configuration changes didn’t stick because it couldn’t save the updates.
Solution (1) was to uninstall a few unnecessary plugins and delete the files from /etc/cmh-ludl before reloading. This cleared enough memory to get it stable.
Solution (2) was to order a Vera3 and transfer the whole configuration across to it.
Vera peppers the log with notifications of memory leaks. I still get them on a stable system with plenty of available memory.
[quote=“RexBeckett, post:108, topic:174138”]You are running very low on memory. I had a Vera Lite that got down to that level. It would restart whenever several things happened at the same time and configuration changes didn’t stick because it couldn’t save the updates.
Vera peppers the log with notifications of memory leaks. I still get them on a stable system with plenty of available memory.[/quote]
That’s what I was afraid of. I just ordered a Vera3!
Of interesting note… I pulled the USB and now logging is better/more consistent. Think you had that one figured out as well. Tried a new one (that I had laying around, but it’s stuck at “re-formatting drive”.
with the new Vera3, should I still use USB logging?
THanks for the help!!!
I have joined my esteemed colleague @akbooer in believing that logging to USB can sometimes cause more problems than it solves. Since I returned to logging to main memory, my Vera3 is more stable and I have more available memory (as reported by EventWatcher). It may be that logging to USB has advantages when memory is in short supply but I am not convinced that the reported gains are real.
OK… thanks again for support. also following your instructions for upgrading tomorrow!!!
Good luck with that. Don’t let your new Vera3 upgrade to UI7. If it does it automatically, contact support and have them remove the suicidal flag.
[quote=“RexBeckett, post:112, topic:174138”]
Good luck with that. Don’t let your new Vera3 upgrade to UI7. If it does it automatically, contact support and have them remove the suicidal flag.[/quote]
My plan is to definitely stay with U15. Will it try to move me automatically?
Apparently some units are shipped with a flag set that causes them to upgrade automatically. When the owners have re-installed UI5, the flag continues to download UI7. Support can remove the flag. If you are lucky, you will get an old-stock unit and avoid the problem.
I also log locally and have noticed greater stability.
I also log locally and have noticed greater stability.[/quote]
Thanks… upgrade went smoothly.
For logging locally… with the Vera3, do you turn on verbose logging?
Not unless I’m debugging. Actually, if you don’t click the “lock levels” check box, verbose is turned off after a set period.
Affirmative. As said on other threads, just start a chat with support and the flag may get disabled within 5 minutes; even on the weekends (or at least on Saturday).
Sorry for the dumb question, but how to i setup info viewer’s log viewer pattern to display multiple log levels?
When i grep the logs via ssh and want to, for example, find all entries that start with 01 or 50 i just grep ‘^01|^50’
but i can not figure out the equivalent pattern in lua for info viewer despite reading as much as could.
Can anyone help a poor lua-impaired guy out?
Thanks !
First of all, the definitive source for documentation on Lua patterns is Lua 5.1 Reference Manual
Unfortunately, Lua patterns do not contain the | operator. The best thing you can try is something like ^[05][10] which would also find 51 but that’s better than nothing.
