since one week I’m owning a very3 controller with a couple of devices. Smoke Detectors, Switch and PowerMeter I got included but inclusion of Fibaro Door/Window Sensor (V2-1) always fails. I tried as eplained in anohter Thread here in the forum but also after a couple of times of resetting/trying do include the device is not visible yet.
I always put the vera 3 in include mode (show up to add new device now …) and then start including mode of device with pressing Button on the back or the internal Button for Three times.
Nothing happens.
Who can help ?
Thanks,
Claus
Hi , have you tried excluding the device, just to clear out any garbage. Just a random suggestion
I just tested to exclude and include, but always 0 (zero) devices. Resetting Sensor a couple of times also did not work. The device is not noticed at the vera3 box
i got mine included by just pressing the internal button and the one at the back quite a few times until my vera started flashing. pressing 3 times did not work for me either, on none of my fibaro door sensors
Just pressing the internal Button once and then the Button on the Back … or pressing the internal Button three times …
As I understand it, the back button and internal button are both normally open tamper switches, connected in series so you need to make sure one is continually closed while pressing the other 3 times (or more) in quick succession to activate the Include…
Hi Frazier,
that worked for me. Keeping the Button on the back pressed and pressing the internal Button for 6 to 8 Times and the include started.
Thanks, now I will configure the device.
Claus
Thanks Frazier & Dawavera33
The easiest way is to keep the cover on and as daeavera33 suggested press the button the rear 6-8 times. Works for inclusion and exclusion
