Took this off my Vera, and trying to include it with the Vera Plus. What device do I chose?
Hello @Grwebster,
If the Z-Wave device you want to pair is not listed on the Pairing Wizard for Vera or Ezlo, you may select the option “Generic Z-Wave device.” Once the countdown starts, the controller will be in inclusion mode, you will need to set the device in inclusion mode too so it gets detected.
The process to set the device to inclusion mode depends on the device model so I’d recommend looking for instructions in the manual. If you need further assitance, don’t hesitate to contact us at support@ezlo.com.
