In wall dimmers and outlets
Hi there!
I want to install in my house in wall dimmers switch and in wall outlets. i need that both of the products will be suitable with vera edge.
In addition i need that the dimmer switch will be with dimming option.
My first question is do i need a special bulb for the dimming option or a regular bulb will be enough?
second question is there any in wall outlet with dimming option? because i want to connect a regular lamp to the wall outlet.
So what do you guys think about those options for in wall dimmers and outlets:
http://www.zwaveproducts.com/Zwave-Lighting/Zwave-Dimmer-Switches/Linear-WT00Z-Z-Wave-3-Way-Wall-Accessory-Switch.html
http://www.zwaveproducts.com/Zwave-Lighting/Zwave-Wall-Receptacles/Linear-WO15Z-1-Z-Wave-Wall-Receptacle-15A.html
If you think there is something better for my needs please let me know
A regular incandescent bulb is dimmable. If you are using CFL or LED bulbs, then they must be of the dimmable type. There are CFLs and LEDs that are NOT dimmable.
Though not in wall, the [url=http://www.amazon.com/gp/product/B00E1OXK3A/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00E1OXK3A&linkCode=as2&tag=zwavec-20&linkId=XUYJZIBARQPRSUOC]Linear PD300Z-2 Z-Wave 300-watt Plug-In Lamp Dimmer Module[/url] and the near identical [url=http://www.amazon.com/gp/product/B0013V6S0Q/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B0013V6S0Q&linkCode=as2&tag=zwavec-20&linkId=IGYXZWMZEPZULIDA]GE Z-Wave Wireless Lighting Control Lamp Module with Dimmer Control[/url] are both dimmers that you can use to control lamps. They just plug in to the existing receptacle.
I recommend against creating dimmable receptacles. They are dangerous, as described below.
So what do you guys think about those options for in wall dimmers and outlets: http://www.zwaveproducts.com/Zwave-Lighting/Zwave-Dimmer-Switches/Linear-WT00Z-Z-Wave-3-Way-Wall-Accessory-Switch.html
This is not a dimmer. It is a remote switch(one button scene controller) for use in 3-way applications(2 switches one light). It is supposed to be used in conjunction with the [url=http://www.amazon.com/gp/product/B00E1OVFAK/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00E1OVFAK&linkCode=as2&tag=zwavec-20&linkId=UIY6UVT7YO5663PW]Linear WD500Z-1 Z-Wave 500-watt Wall Mount Dimmer Switch[/url] which is the dimmer switch you want.
This is a switchable receptacle. It is not dimmable. Though some people do setup dimmable in wall receptacles by using a dimmer switch or an in wall [url=http://www.amazon.com/gp/product/B00IRQC7O6/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00IRQC7O6&linkCode=as2&tag=zwavec-20&linkId=BK45MXGI54JBAZWC]Aeon Labs Aeotec Z-Wave Micro Smart Energy Dimmer[/url] to control a standard receptacle, I strongly recommend against this type of installation. [u]It is dangerous![/u] Dimmers cannot handle the necessary load if something like a vacuum cleaner was plugged into the receptacle and you could cause a fire. Also, plugging electronics into a dimmed receptacle could have a bad effect on the electronics. The plugin dimmers I linked to are less susceptible to accidental misuse.
tnx for the answers
but just to make it clear , if i have 1 room with 1 light and 1 switch this is what i need right?
and if i have 1 light 2 switches this is what i need (together with the dimmer)
That is correct. The WT00Z-1 is a secondary switch used to control the WD500Z-1.
You can use several WT00Z-1 switches(up to 5?) with a WD500Z-1.
Tnx a lot :wink:
