I pulled a touchscreen monitor out of recycling at work and would love to integrate it into my home automation. I have a raspberry pi I am not using, anyone know of a way to put imperihome on it??
Thank you!
Thank you!
[quote=“bwoods113, post:1, topic:186637”]I pulled a touchscreen monitor out of recycling at work and would love to integrate it into my home automation. I have a raspberry pi I am not using, anyone know of a way to put imperihome on it??
Thank you![/quote]
Does said monitor have a HDMI input? If so, you could get one of those Tronsmart Android sticks to hook up to it. Functionality of the touchscreen would depend on if it requires special drivers. Otherwise, use an old PC with andyroid emulator as to the best of my knowledge, Imperihome does not work on a Pi. Unless they changed that recently.
There is some work being done to get Android running on the Pi. Not sure how far along it is.
https://www.mepits.com/project/180/DIY-Projects/How-to-Install-Android-on-Raspberry-Pi-?
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
