ImperiHome Keeps Waking Up
Hello,
I have ImperiHome running on two dedicated tablets. I have ImperiHome set to sleep after one minute. Something has changed with both tablets that is causing ImperiHome to wake up every few minutes. I can’t seem to figure out what is causing it. I’m hoping that someone can help me identify the application/process that is causing this.
If it helps, both tablets are the ASUS MeMO 7 (me176cx) and both are rooted.
Thanks.
[quote=“SJMarty”]Hello,
Thanks.[/quote]
Imperihome has a setting for the camera detecting movement to wake the tablet up. Maybe something is triggering that.
Sent from my SM-G900V using Tapatalk
[quote=“quie2droid, post:2, topic:188898”][quote=“SJMarty”]Hello,
Thanks.[/quote]
Imperihome has a setting for the camera detecting movement to wake the tablet up. Maybe something is triggering that.[/quote]
Thanks for the reply. As it turns out, there is a setting on my Vera3 to “scan local network for devices” and that box was checked. I’m not sure if it’s always been there or if it was added/turned on by a firmware update but unchecking it stopped ImperiHome from waking up.
