I’ve been using Schlage/Nexia at my second home/vacation rental located 1000 miles from my home. I’ve only used it for the front door lock and to control the the thermostat. I’m sure that Nexia has other features as well, but it seems just by the mere volume of activity on this site that micasaverde may be a better route.
Please bear in mind that even though I’ve had the system since 2006, I’m a Newbie. I would like to accomplish the following:
Control the lock to the front door (meaning being able to set the lock codes and lock/unlock the door via Laptop and Android).
Monitor the temperature, set the thermostat, set thermostat limits.
Monitor and adjust the temperature of the hot tub.
Schedule and/or turn on and off the sprinkler system
These are just the basics that I would like to be able to do. I have a Trane Thermostat and I assume that it would work with micasaverde also. I will probably change my front door lock since I stupidly installed one that you have to turn the deadbolt to gain entry, thus eliminating the ability to lock and unlock the door remotely.
I would appreciate any input that you may be able to give me, especially from those who have used Nexia in the past. And if there are any other ideas that I might employ, both for safety and for cost savings, I would really appreciate the input.
Oh, and by the way, I read something about Insteon and don’t know exactly what that is. Is that an alternative to z-wave?
Thanks in advance
