i want to use a standard electric door latch with vera lite
i have a standard Yale electric door latch (12v) which i have connected to a 12v adapter connected to a figaro wall plug 2500w. which is controlled by a vera lite . I have written a scene to power the wall plug for 1 second and then immediately cut power, so that i can trigger the latch to open. This setup is working ok, only sometimes i have to trigger power for 2-3 times to get the latch to open. Can somebody suggest a more efficient way of completing this job.
Thanking in advance
Have you tried powering it for longer?
Say 5 seconds or 10 seconds?
This is similar/related - have a look at this. - http://forum.micasaverde.com/index.php/topic,12514.0.html
