Good day!,
I have a question about the setup I have at home, first a brief overview:
Vera 3 is installed in my house with some devices.
Vera lite is installed outside (100 meters away from the house) and slaved to the vera 3. with some devices.
This setups works good, I can activate the devices which are setup on the vera lite via the vera 3. The devices on the vera lite are shown on the vera 3.
But vice versa, it doesn’t show. when I logon the vera lite, I don’t see any devices which are setup from the vera 3.
The reason why i ask is , i have an aon mini labs remote and i want to operate it via the network on the vera lite , but I also want to operate some lights which are setup on the vera 3.
In short:
I press a button on the aon minilab remote, this will activate a scene which i have setup on the vera lite.
But the scenes I can programm on the vera lite , only shows devices from the vera lite and not from the “master” vera 3…
Did I do something wrong or can you not controll devices from the “master” on the “slave”"
many thanks,
Cor
