I can't make the push notification plugin run
I hope I’m not wearing you out.
I’ve got the plugin installed and I’ve got a device identifier set but, I can’t operate it and it can’t connect it to a scene.
I see Automator.app on the list of all devices but, there’s no controls. There’s nothing for the scene to operate.
When I set a “Contolled via” value, the device disappears.
Due to limitations in UI5 you cannot enter the message on the Automator.app device when setting up the scene. Instead you need to select the Automator.app device from the “Advanced” tab when defining the scene. From there you can use the SendPushNotification method to define the actual text. See attached image.
Thanks, that did it.
