hi
I have vera2 where I have problem to config Motion sensor then I have given the old version UI3 1.1.329-1.trx and It was successfully installed but as the version is too old so I again give the latest version but after that the problem is started i can not access the interface via 192.168.0.55 or Findvera.com
SO please response if anyone have any idea.
Do you update to UI4? If yes, you have to use cp.mios.com instead of findvera.com
On the other hand the local IP address usually is 192.168.81.1
