I recently added the app for the wifi 3M therm and it is working but the log repeatedly shows this error
02 10/07/12 23:19:36.338 luup_log:14: RTCOA INFO (callThermostatAPI:308) - retrying request, path = /tstat, retry #7 <0x2ca53680>
01 10/07/12 23:19:41.340 luup_log:14: RTCOA ERROR (doHttpRequest:244) - Received bad HTTP response <0x2ca53680>
01 10/07/12 23:19:41.341 luup_log:14: RTCOA ERROR (doHttpRequest:245) - URL: http://192.168.1.64/tstat <0x2ca53680>
01 10/07/12 23:19:41.341 luup_log:14: RTCOA ERROR (doHttpRequest:246) - postData: nil <0x2ca53680>
01 10/07/12 23:19:41.342 luup_log:14: RTCOA ERROR (doHttpRequest:247) - Status: timeout <0x2ca53680>
01 10/07/12 23:19:41.342 luup_log:14: RTCOA ERROR (doHttpRequest:248) - Body: nil <0x2ca53680>
01 10/07/12 23:19:41.343 luup_log:14: RTCOA ERROR (doHttpRequest:249) - Headers: nil <0x2ca53680>
01 10/07/12 23:19:41.343 luup_log:14: RTCOA ERROR (callThermostatAPI:313) - Received no response (timeout?), path = /tstat <0x2ca53680>
i eventually see successful communications but I assume that one of the status routines is wrong for my thermostat and this is causing a slowdown in my vera 3 ui5
I can control all of the functions and get the proper statuses. is there a way to stop the request that is failing?
