I am getting an error everytime I try to login
Hi I am getting an error that says invalid username/password when I try to login. I am using the same password that I use for login to home.getvera.com / MiOS account.
Edit: I found the problem, I am on UI6. When will iViri Support UI6? or How can I go to UI5?
I will be working on the MMS authentication shortly. Stay tooned!
same for me now after a fresh install on my iPhone 5s iOS 8.1 (connecting to a vera 2, UI5), any news on this?
I have spent most of my free time that I have had outside of work getting my openHAB setup working and demoting the Vera unit to just a z-wave master. My OpenHAB handles everything and handles it a lot better. Also have an app coming out for location awareness to any restful service called GeoReactions. I will be updating iViri to work with iOS 8 and look correctly, but have no plans as of right now to make iViri work with anything higher than UI 5.
I have spent most of my free time that I have had outside of work getting my openHAB setup working and demoting the Vera unit to just a z-wave master. My OpenHAB handles everything and handles it a lot better. Also have an app coming out for location awareness to any restful service called GeoReactions. I will be updating iViri to work with iOS 8 and look correctly, but have no plans as of right now to make iViri work with anything higher than UI 5.[/quote]
Any update on how this is going? I had iviri working for a little while, but then it started giving me the network connectivity error message again and won’t let me log in.
Thanks.
