i started to modify the default D_HVAC_ZoneThermostat1 file in order to Remove the Heating elements as they not cupported by many devices, so its nice to have some sort of optical seperation.
i managed to remove all Buttons not used/needed/working but somehow there are 2 issues left.
the Blue selector has turned RED (for warm) … well its just the color … everything does work anyway.
the window is not getting smaller at all … does anyone know how i do define the thermostate window size ?
maybe anyone could help me out in what i do wrong ?
My search-fu is failing me at the moment, so I can’t find the old thread. In a nutshell it said: There are a lot of hardcoded assumptions about HVAC devices in the JavaScript of the Vera UI. If I recall, one of those hardcoded assumptions is that if there is one vertical slider then it will be red, and if there is a second if will be blue. (Also the string “Heater” in the device URN is searched for specifically in places in the JavaScript.) You may be out if luck if you want the colour to match “cooling” only.
Thank you for your help Rex … got it sorted out …
just the issue about the Drawer has turned red … but i think that is not so serious …
also removed the heating settings and heating related triggers …
[quote=“Alireza44907, post:5, topic:181364”]Hello
To get this app an implementation file is needed.
How can I get it?[/quote]
This thread is not about a plugin. The thermostat is a Z-Wave device so no Implementation file is needed. The modifications were intended just to customize the UI display.
If you tell us what model of thermostat you have, which type of Vera and which version of UI you are using we may be able to help. Also tell us what is/is not working and what you expected.
@slajgaj
i have this working on serval different termostates … IR and cable ones … with no issue,
the only “problem” is that the Temperature Drawer defaults to Heating “red color” but works anyway…
so it would be really interesting indeed to know the informations about your infrastructure
