I have a Trane Z-Wave stat on the upstairs furnace and am generally pleased with the way it integrates with Vera. I run the programs with Vera but the setup still allows for override at the stat. I now want to put in a stat for the main level, but also want to control the whole-house humidifier. Based on my research, it seems that either the CT80 (or its variants) or the Next Gen 2 would fit the bill best. It seems that folks are happy controlling the Nest over WiFi, but the CT80 can be WiFi and/or Z-Wave. Seems that both would require a relay as I have a 2-wire humidistat.
Could folks that have either stat (that are controlling humidity via the stat) chime in with your experience?
Is it reliable?
Can this setup be automated (at Vera) in ways comparable to the native stat control in UI5?
Does UI5 allow for humidity control natively or does it require a plugin?
[quote=“DaveL17, post:1, topic:174549”]I have a Trane Z-Wave stat on the upstairs furnace and am generally pleased with the way it integrates with Vera. I run the programs with Vera but the setup still allows for override at the stat. I now want to put in a stat for the main level, but also want to control the whole-house humidifier. Based on my research, it seems that either the CT80 (or its variants) or the Next Gen 2 would fit the bill best. It seems that folks are happy controlling the Nest over WiFi, but the CT80 can be WiFi and/or Z-Wave. Seems that both would require a relay as I have a 2-wire humidistat.
Is it reliable?
Thanks in advance,
Dave[/quote]
The Nest (and soon ecobee) thermostat plugins will report the current relative humidity, but neither plugin will (yet) surface the wet and dry setpoint(s) for the purpose of control. However, at least one Nest plugin user has set up automation to turn off/on a humidifier based on outside temperature and inside relative humidity. I know the 2nd gen Nest has [de]humidifier control, as does the ecobee, but the plugins only show relative humidity. I have not found an existing device type in Vera that is analogous to HVAC_ZoneThermostat but for humidity, and I’ve been waiting for user input to add humidistat control to the Nest plugin.
Based on your post, it sounds like the humidifier control was done with supplemental automation? That is, putting the humidifier on its own device and firing that (or not) based on relative humidity as reported by the thermostat (via the plugin)?
So I’d need to know:
Outside Temp – to calculate the target humidity
Inside Humidity – to know if humidifier is called for
Heat = True – to only fire the humidifier when heating
Based on your post, it sounds like the humidifier control was done with supplemental automation?[/quote]
You’re welcome! You are correct that Chuck did this with his own automation based on relative humidity changes, using a Z-Wave switch to turn humidifer(s) on and off as needed. Here is the relavent page in the forums: [url=http://forum.micasaverde.com/index.php/topic,10508.105.html]http://forum.micasaverde.com/index.php/topic,10508.105.html[/url]. He found the “recipe” for setting indoor relative humidity based on other variables (in the cited thread).
Of course, if your whole house humidifier/dehumidifier were wire-compatible with the thermostat, you could just connect them up that way and have the thermostat flip the switches. Chuck’s solution is probably smarter at setting inside relative humidity, but it depends on how much information the thermostat has and what it does with it when trying to calculate and reach the setpoints itself. I think the Nest has a single relative humidity setpoint, but I’m not sure how it would work to try to reach that single setpoint. (I don’t have a whole house [de]humidifer, so this has been academic to me.)
Thanks again. You’ve given me a lot to think about.
Both the Nest 2 and the CT80 are wire compatible with my humidifier – but they both require a simple relay (because the thermostats are one wire and my humidistat is two wire.)
I’d like to have the thermostat handle the switching unless there’s a compelling reason not to. Just seems simpler to me–maybe I’m missing something…
I use the CT-80 with a humidifier - there are two setups, depending if your HVAC powers the humidifier or ext power. Mine had a transformer with two wires going to the humidistat.
Mine works fine with the other wire tied to RH as described below.
Thanks TMatt. I wound up pulling the trigger on the Nest; but I have yet to hook up the humidifier. I expect that the wiring is essentially the same for both, though.
