Equipment:
Brand new VeraEdge running 1.7.1181.
A GE12722 switch: http://www.amazon.com/GE12722-Z-Wave-Wireless-Lighting-Control/dp/B0035YRCR2/ref=lh_ni_t?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
A Cooper Wiring Devices RF9540-NAW Aspire dimmer: http://www.amazon.com/gp/product/B00EZVM6SY?psc=1&redirect=true&ref_=oh_aui_detailpage_o06_s00
Both z-wave devices were added to my Vera using the Generic Device option, since I couldn’t find these specific products in the device list.
I tried to set up a scene in the Vera UI as follows:
TRIGGER: Whenever the GE12722 is turned ON. (No restrictions added.)
DEVICE ACTIONS: Immediately turn the RF9540-NAW dimmer ON to 100% brightness; Send notification to me.
So then I go to test this triggered scene. When I turn the GE12722 on manually by pushing the switch, the light it’s connected to turns on immediately (of course), but it takes as long as 60 seconds for the RF9540-NAW to turn on and the notification to be sent. Why is there this huge delay?
I assume the GE12722 is not immediately reporting to the Vera hub that it was turned on? Is there a way to fix this? It makes the trigger kind of useless.
Thank you so much for any insight!!!
Jake
