Hue Error
I get this error, which turns off one of my Hue lights. Any ideas what this is? I believe this happens when when Vera is polling Hue. Thanks
01 08/28/14 22:24:12.446 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 1408 <0x2b
I get scads of those in my logs:
01 08/29/14 13:11:40.559 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 1018 <0x2b5d8680> 01 08/29/14 13:11:41.750 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 2388 <0x2b5d8680> 01 08/29/14 13:11:42.206 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 1128 <0x2b5d8680> 01 08/29/14 13:36:09.535 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 1018 <0x2beb2680> 01 08/29/14 13:36:10.746 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 2388 <0x2beb2680> 01 08/29/14 13:36:11.206 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 1128 <0x2beb2680>
It doesn’t look like it’s specific to the Hue plugin and it doesn’t look like it’s actually a problem.
It happens exactly when it turns a hue light off when it should be off. I turn the light back on manually, but the next time vera poll hue, the light is turned off.
It’s device 10 below, note how the log entry is differnt than the other hue devices.
01 08/28/14 22:24:12.446 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 1408 <0x2b475680>
06 08/28/14 22:24:15.678 Device_Variable::m_szValue_set device: 3 service: urn:intvelt-com:serviceId:HueController1 variable: LinkStatus was: Hue hub is up and linked now: Hue hub is up and linked #hooks: 0 upnp: 0 v:0x9c0030/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.678 Device_Variable::m_szValue_set device: 7 service: urn:intvelt-com:serviceId:HueColors1 variable: ColorTemperature was: 62 now: 62 #hooks: 0 upnp: 0 v:0x9e8a18/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.679 Device_Variable::m_szValue_set device: 7 service: urn:intvelt-com:serviceId:HueColors1 variable: Hue was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9e96d0/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.679 Device_Variable::m_szValue_set device: 7 service: urn:intvelt-com:serviceId:HueColors1 variable: Saturation was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9e96b0/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.680 Device_Variable::m_szValue_set device: 9 service: urn:intvelt-com:serviceId:HueColors1 variable: ColorTemperature was: 62 now: 62 #hooks: 0 upnp: 0 v:0x9e8a18/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.680 Device_Variable::m_szValue_set device: 9 service: urn:intvelt-com:serviceId:HueColors1 variable: Hue was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9e96d0/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.680 Device_Variable::m_szValue_set device: 9 service: urn:intvelt-com:serviceId:HueColors1 variable: Saturation was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9e96b0/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.681 Device_Variable::m_szValue_set device: 10 service: urn:upnp-org:serviceId:Dimming1 variable: LoadLevelStatus was: 50 now: 0 #hooks: 5 upnp: 0 v:0xaf2b88/NONE duplicate:0 <0x2bc75680>
06 08/28/14 22:24:15.736 Device_Variable::m_szValue_set device: 11 service: urn:intvelt-com:serviceId:HueColors1 variable: ColorTemperature was: -45 now: -45 #hooks: 0 upnp: 0 v:0x9e8a18/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.736 Device_Variable::m_szValue_set device: 11 service: urn:intvelt-com:serviceId:HueColors1 variable: Hue was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9e96d0/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.737 Device_Variable::m_szValue_set device: 11 service: urn:intvelt-com:serviceId:HueColors1 variable: Saturation was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9e96b0/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.737 Device_Variable::m_szValue_set device: 59 service: urn:intvelt-com:serviceId:HueColors1 variable: ColorTemperature was: 62 now: 62 #hooks: 0 upnp: 0 v:0x9e8a18/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.738 Device_Variable::m_szValue_set device: 59 service: urn:intvelt-com:serviceId:HueColors1 variable: Hue was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9e96d0/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.738 Device_Variable::m_szValue_set device: 59 service: urn:intvelt-com:serviceId:HueColors1 variable: Saturation was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9e96b0/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.739 Device_Variable::m_szValue_set device: 61 service: urn:intvelt-com:serviceId:HueColors1 variable: ColorTemperature was: 62 now: 62 #hooks: 0 upnp: 0 v:0x9e8a18/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.739 Device_Variable::m_szValue_set device: 61 service: urn:intvelt-com:serviceId:HueColors1 variable: Hue was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9e96d0/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.739 Device_Variable::m_szValue_set device: 61 service: urn:intvelt-com:serviceId:HueColors1 variable: Saturation was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9e96b0/NONE duplicate:1 <0x2bc75680>
06 08/28/14 22:24:15.740 Device_Variable::m_szValue_set device: 3 service: urn:intvelt-com:serviceId:HueController1 variable: LinkStatus was: Hue hub is up and linked now: Hue hub is up and linked #hooks: 0 upnp: 0 v:0x9c0030/NONE duplicate:1 <0x2bc756
