https problem
Hi.
Just trying to get started with VeraConcierge. I have it running on a Raspi. Accessing it is no problem, BUT I can only access http://:8989 and http://:8998 from any browser in my network. I cannot access it through https - that gets a timout.
Connectivity check fails, since that trys to connect using https and so I am stuck.
Haven’t found anything useable in the logs :frowning:
Any help or pointer appreciated. (Is there a way to start ConciergeServer with a higher logging level?)
Thanks,
/Erik
