I?ve created a simple HTML page to control a device. When I click either link, the controller returns XML. Now I need to add logic to process the result of the request. Am I correct to assume that if a job number is returned, the task was completed? If the URL is incorrect, ?ERROR: Invalid service/action/device? is returned. Should I query the device for the status? Is there documentation that lists return codes/text for URLs?
wuT2w*
Have you looked at the wiki pages? There is a section on how to build your own GUI which may help you [url=http://wiki.micasaverde.com/index.php/UI_Simple]http://wiki.micasaverde.com/index.php/UI_Simple[/url].
Ignore the bit about connecting remotely as that is obsolete. Also the local url should read http://[vera ip]/port_3480/… The :3480 use as shown in the wiki will be blocked in a future release for security reasons.
Cheers Rene
I did look at that page, but it describes a complete user interface (user authentication, for example) written in C++. Much more than I need. I did dig a little deeper into the .zip ([url=http://wiki.micasaverde.com/index.php/UI_Simple_Sample]http://wiki.micasaverde.com/index.php/UI_Simple_Sample[/url]) and may be able to use some of the code as at least pseudocode.
A rewrite. No error checking. Next version to check device status and use two images to appear to toggle on/off.
My goal is to create an interface to run on Raspberry Pi.
<!DOCTYPE html>
<html>
<body>
<h1>Lights</h1>
<h2>Office</h2>
<button type="button" onclick="SendAction(1)"><img src="lighton.png"></button>
<button type="button" onclick="SendAction(0)"><img src="lightoff.png"></button>
<p id="msg"></p>
<script>
function SendAction(NewState) {
var xhttp=new XMLHttpRequest();
URL="http://192.168.1.20:3480/data_request?id=action&output_format=xml&DeviceNum=6&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue="+NewState;
xhttp.open("POST",URL,true);
xhttp.send();
/*Use the following to update elements on the page. Currently displays Vera job #.
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("msg").innerHTML = this.responseText;
</script>
</body>
</html>
Have you looked at ALTUI with openLuup as that gives you just that? Add the Virtual Panel plugin you can design a panel just as you like it.
But, I can imagine you want to build your own as I also like a level of control I can make my self using LUA code rather then using PLEG, Workflows or what ever.
For future compatibility you have to change your URL to http://192.168.1.20/port_3480…
Have fun.
Cheers Rene
I have AltUI app installed. I do not see the Virtual Panel listed as an app. Are you referring to the AltUI Panels menu?
I originally started out repurposing a Samsung Android tablet to become a wall-mounted display of weather, radar, and z-wave devices (via ImperHome). It does work well, but has problems. Mostly the lack of security and battery drain even connected to AC power.
(For the tablet, I used the apps MyRadar, Weather Station, Caffeine, ImperHome, and Tasker.)
This is the Virtual Panel plugin [url=http://forum.micasaverde.com/index.php/topic,31128.375.html]http://forum.micasaverde.com/index.php/topic,31128.375.html[/url].
ALTUI indeed has a custom panel option too.
Cheers Rene
