Agreed and we appreciate your efforts. I have been working with HTD on some of the updates and wondered if you have any planned releases anytime soon. I have been testing the unit on a lync 12 and can not seem to get the volume setting to work on any command. Before testing much more, should it be working? I know you are having issues with the slider, however just setting the volume doesn’t seem to work either? I will gladly help if I can.
Hi
The volume is related to a file that Vera always had on the Vera system but for some reason it has been removed it is the Volume2 file attached if you load that into the system it will provide a working volume. I have been drove crazy at work over the last few months working night and day. Hopefully all will be completed very soon and give me a little time to please again.
I tried the volume file , does not seem to work.
[quote=“Newzwaver, post:22, topic:195450”]Hi
The volume is related to a file that Vera always had on the Vera system but for some reason it has been removed it is the Volume2 file attached if you load that into the system it will provide a working volume. I have been drove crazy at work over the last few months working night and day. Hopefully all will be completed very soon and give me a little time to please again.[/quote]
Any changes to the volume plugin? I cant seem to get the volume to work either?
Hi
If its the MC66 yes the volume will work but you take a change that it will lock up your MC66 system and will need to turn off/on. I crashed my computer so will have to check the hard drive.
Thanks I?ll double check the upload i currently have a lync 12. I dont need a fnacy slide or anything. Just the ability to set a specific volume. I know you do this pro bono. However i really appreciate the help. With the volume fix I will be set
Sorry All, I have been busy with work and home no automation over the last years.
If you have questions on the plugins I developed please message me.
