Hi, I have a HSM100-S3 motion sensor that around every 6months it quits communicating with Vera on the motion side. When I remove the device from the system and re-enroll it, it works again and the motion is reported correctly. I’m getting sick of this happening since when I delete it I have to reconfigure all my luup code which is a pain in the rear. Does anyone know of any special way to reset the Zwave device so I don’t have to delete it from the system? It’s really weird because the temp and light sensors report in on the device, but the motion doesn’t until I delete the device and re-enroll it again. If there is any special way to reset the device and get it working again without deleting it, boy I would really be thankful to know this information. I have tried to issue the configuration device command, but that does work either.
Tnx,
Rob
