HSM100 Problem Adding to Vera2
Has anyone tried adding the HSM100 to Vera 2?
I press the blue button on the HSM100 but and the z-wave button on Vera. Eventually the z-wave light goes back to solid but the HSM100 isn’t added.
The is an old post about excluding it before you try including it ut how do you do this on Vera 2?
I just got my vera2 about an hour ago so I don’t really know what I’m doing so take w/ a grain of salt. I had same symptons so put in exclude mode first by holding down z-wave button for 3 seconds and hitting blue button on HSM100. Then came back in include mode by hitting z-wave button again for just a second and then hitting blue button on HSM100 and picked it up. Its the first device I’ve added. Don’t know quite what to do with it now but thats my next problem.
I’ve got a Vera2 also, and the HSM100 installed without much trouble. If Vera detects that you’re adding a new device to your network, the Z-Wave light should flash very quickly for a second or two. That’s when you know that your device inclusion worked.
Did you ever get your HSM100 units working?
