I added this device and it was sending messages back and forth to my Vera3. All worked well, I would say that it never really relayed the true temperature, but the motion sensor and the light sensor were on point.
I even had each function in my device tab under Climate. Then the device did not work right, so I deleted it (read the online forums and it says that deleting the device isn’t very helpful) and re-installed it but now the Vera3 DOESN’T recognize the device anymore.
The best it can do is make it a generic Sensor without any functions. I rebooted my laptop, Vera 3 and the HSM100 but to no avail. Any help would be greatly appreciated. Thank You
[quote=“Vera3newbie, post:1, topic:170020”]I added this device and it was sending messages back and forth to my Vera3. All worked well, I would say that it never really relayed the true temperature, but the motion sensor and the light sensor were on point.
The best it can do is make it a generic Sensor without any functions. I rebooted my laptop, Vera 3 and the HSM100 but to no avail. Any help would be greatly appreciated. Thank You[/quote]
If you “deleted” the device it will not install corectly, you must “Exclude” it, you can do so even if it’s not in your network, then it should reinstall correctly
