Associating more than one device with my HSM100 doesn’t seem to work. As of firmware 1.0.900 Vera cannot configure my HSM100, if there is more than one association (-> red cog). Is this a known problem? According to the EZMotion manual the HSM100 should support up to four devices.
Does it work ok if you just associate a single device?
also, what devices are you trying to associate?
Yes, a single associated device does work. Both associated devices are merten 5024xx, 5034xx, 5044xx (see http://wiki.micasaverde.com/index.php/Supported_Hardware#Lighting_Devices) with identical firmware revisions.
Same for me. I just tried associating two lights and get the same constant red cog. works fine for one.
Time to open a ticket
Done. ID #705.
@MCV
I hate to necropost, but is there any update about this bug?
I moticed that you’re running slightly older version and I am almost certain that it’s just the signature and may not be your actual version that may cause the trouble in question.
my 0.002 c
regards
Kepper
