My Minimotes (3) all seem to go insane periodically. the solution I found was to REMOVE them from the Zwave network, RE-ADD them to Zwave, and configure the scenes (once), save, wait for the confirmation. Make sure to log back into your Vera after you configure the scenes; I assumed the set didn’t work because I didn’t see the scenes…
I followed the directions from posting 47. To make the minimote dim the lights up and down for a long press, but when I short press to save the light level. It jumps back to 100%. How can I get the minimote to stop at the light level I want when holding down the long press to dim.
Just bought a new Vera Edge with UI7 after my Vera 2 recently died. My 2 minimotes worked perfectly as long as the Vera 2 had been working.
Now I’m unable to get these to work with the new Vera Edge. I have tried the UI7 instructions in posts #106 and #119 without any luck. I have paired them using both “Other zwave device” and “Generic wave device.” I have tried configuring with and without setting the number of buttons in the device settings. I have tried adding the remote directly to scenes using device triggers “scene number X is activated” (and deactivated). I can’t get any combination of these to work. Between each attempt, I have reset the remote by pressing the associate and learn buttons until the blinking stops.
Do you think that it’s the new Vera Edge? It has been working well so far except for this problem. Please let me know if you have any suggestions. Thanks.
I’m in a similar boat. I added one of mine a few weeks ago. It shows up correctly and has settings for scenes for both on and off states for all 4 buttons. I added a new one today and don’t get the off states, and despite binding it to scenes nothing appears to happen when I press any buttons.
This is on a Vera3.
[quote=“stumax, post:123, topic:169756”]Just bought a new Vera Edge with UI7 after my Vera 2 recently died. My 2 minimotes worked perfectly as long as the Vera 2 had been working.
Do you think that it’s the new Vera Edge? It has been working well so far except for this problem. Please let me know if you have any suggestions. Thanks.[/quote]
Follow-up: I have both minimotes working now on Vera Edge with UI7. Both were added through the inclusion mode enabled via the iOS Homewave app. It’s on the Vera settings screen. I assume the the external inclusion button would work too.
I did not configure the number of buttons in the device settings. Each button was added individually as a device trigger for one of eight different scenes. All working properly now.
As above, I couldn’t get the minimotes to work through the vera web interface.
Anyone having success with Vera Edge and UI7 through the web?
I have the device included in Vera and I did the reconfigure, which polled the version number from the device (I have updated it to the latest firmware before that), so I believe Vera can talk to the remote just fine.
However pressing or holding the scene buttons does nothing despite everything looking okay in the Vera config.
How To Set Up Vera3 with MiniMote DSA03202v1:
- Go To: http://www.aeon-labs.com
- Update your MiniMote Firmware to 1.19.
- Reset your MiniMote: Hold “Blank” and “Join” buttons down together until the lights stop blinking.
- On your Vera3 (go to "Devices=>Add a Device=>Hand Held=>Key Fob (Z-Wave Me Key Fob).
- Go through the Device setup until the Vera3 z-wave light is blinking slowly.
- Take your MiniMote close to the Vera3 and push the “Join? button”.
- The z-wave LED on the Vera3 and the LEDs on the MiniMote will start to blink fast and stop again.
- Wait a couple of minutes until the lua engine is restarted. Wait 2 minutes. The z-wave light on the Vera3 may or may not be blinking anymore. You might need to click elsewhere to exit the setup now.
SEQUENCE: Set Up Scene using Manual Trigger-Get Scene Number-Edit Scene-Change Manual Trigger to Remote-Choose Activate (for Short push) OR Deactivate (for Long push) then enter Scene number you are editing-Validate and finish.
- Go to “Scenes” on the Vera3. Setup the scenes you want using the Device=Manual. You will come back later and tie it to the MiniMote. Setup one scene for ON(Activated) and one scene for OFF(Deactivated) as each of the 4 buttons on the MiniMote can be programed to do 2 things.
Write down the Scene numbers to identify it/them for the next step.
Go to ?Scenes? again. NOW edit each scene you just set up and change the trigger to be a Device then choose the MiniMote. It will show that the MiniMote is now the trigger but the internal scene number must be assigned from 9 above. Once done, validate then go to Finish.
LAST-Go to “Devices” on the Vera3. Choose the MiniMote to Edit. Go to Select Scenes to be assigned to Buttons. Assign Scenes set up above to each Button.
MiniMote: On = Short press of button OFF = Long press of button
Now the scenes should show all the buttons assigned and the scenes with the scene #s. Be sure to click Save Changes.
Hi guys,
Also worked a bit with the minimote and this delay really makes calling the scenes a bit unpredictable (if you need for example slightly open the blinds but need to wait this delay until Vera gets the next stop command).
Do you know if this is a remote controller hardware behavior or somewhat in the mios code? Any possible way to bypass it (tried to reset last scene variable in mios but it didn’t help).
Would really appreciate any suggestion,
Thank you,
Dmitry
[quote=“oTi@, post:48, topic:169756”]…
Notes:
[size=8pt]Because the short press double as on/off and stop action, you can not go to the off state immediately after changing the level; there is a time-out, currently set at 4 seconds.
Also, the poll after on/off is done with a delay, currently set at 3 seconds, to give the dimmer time to ramp up/down to the final state; otherwise the wrong value will be polled.
So when testing this, keep the slightly altered button behavior and the time-outs/delays in mind.[/size]
…[/quote]
I don’t see/feel there is a (noteworthy) delay with my two Minimote under VeraLite UI5.
Ok. But if you click a button (short click) and then in a second click it (short one) again - will the scene runs twice? or the second time it will skipped?
Thank you,
Dmitry
I would say skipped, because there is interruption in the scene. On key1 I have two scenes, short click for shutters up, long click for shutter down. Let’s assume the shutter is down and I click (short) key1 inside a second or so twice, there will be no interruption in the movement of the shutter.
Hello,
I tried to connect a minimote to my new Vera Edge. I followed the whole procedure, the device is listed correctly.
the scenes are existing and running well but the remote push buttons fail to activate the commands .
What else can I do ?
Thank you ,
Dan
[quote=“chixxi, post:1, topic:169756”]So after updating my Vera2 to UI5 / Firmware 1.5.233 I just added the Aeon Labs MiniMote (Firmware 1.17) as a secondary zwave scene controller, AND IT’S A FULLY FUNCTIONAL SCENE CONTROLLER!
I can run predefined scenes on the vera using the Minimote! See Screenshots attached:
HowTo (or at least what worked in my case):
- Go To: http://www.aeon-labs.com/site/products/view/3/
- Update your MiniMote Firmware to 1.17.
- Reset your MiniMote: Hold “Associate” and “Learn” until the lights stop blinking.
- On your Vera2 (has to run on UI5 1.5.233 or 1.5.255) go to “Devices=>Add a Device=>Advanced zwave devices” Add a secondary" battery operated handheld remotes"
- Now the zwave light on your vera starts blinking slowly.
- Take your MiniMote close to the vera and push the “Learn Button”.
- The zwave led on the vera and the leds on the minimote will start to blink fast and stop again.
- Wait a couple of minutes until the lua engine is restarted and the zwave light on the vera is not blinking anymore.
- The go to “Devices=>Other” in the vera UI5. Click the wrench-button (settings) of the device “_MiniMote”.
- Choose which scene to run on which button in the “Scenes”-Tab
- Close the Settings Window and click save.
- Wait for lua to restart and try.
Works on ver2 and vera3.[/quote]
I recently upgraded my Vera Edge to v1.7.1142 and now the Minimotes no longer work correctly.
I followed all the info from the last few pages and no matter what i do I can only program button 1 and 2 correctly on a quick press.
So avoid 1.7.1142 if you use the Minimote and the Edge.
Same problem here. Have tried setting up without going to scene selection on device. And through scene selection on device. Button 1 does nothing. Button 2 does what is assigned to button one. And so on. So weird.
Programming the MiniMote was never very straightforward but I had it figured out. That is until I upgraded to the Vere Edge Firmware version 1.7.1142. No, as with other people, I can only get Button 1 to work. I can at least get it to turn one scene on (short push) / off (long push). Buttons 2,3,4 are all non-functional! What a mess!
Hello,
Since the last UI7 update, the problem has been solved. (1.7.599)
Thanks for the devellopers ! ;D
Ok, I’m going to ask a simple question has anyone got the Gen5 Aeon Lab Minimote to work with the latest UI7 (vera 3)? If so would you take some time and edumate (sic) us on how you were able to get your minimote to work with all eight buttons? Parsing through the various threads I see how to setup the older version minimotes but not the newer one. Many thanxs in advance.
Update - I started a new thread specifically centered around UI7 and the Gen 5 MiniMote. “Aeon Labs MiniMote (gen5) functional Scene Controller in UI.7 version 1.7.599”[url=http://forum.micasaverde.com/index.php/topic,32670.0.html] http://forum.micasaverde.com/index.php/topic,32670.0.html[/url] and provide the procedure to getting it to work.
To add the device I recommend using the Handheld Aeon KeyFob if you have the V1 MiniMote and the Aeon KeyFob Zwave+ if you have the V2 MiniMote
Keep the MiniMote very close to Vera when pairing, and let the timer run out to give the Vera time to configure the remote, then hit Exit.
The Button Mapping has changed:
Note that if you don’t get 8 buttons listed on the Scene’s menu by default the pairing wasn’t fully successful, delete and start again.
Button 1 (upper left) - 1
Button 1 Long Press -2
Button 2 (upper right) - 3
Button 2 Long Press - 4
Button 3 (lower left)- 5
Button 3 Long Press- 6
Button 4 (lower right)- 7
Button 4 Long Press- 8
So this one works fine with Vera Edge, running latest juni firmware?
edit: yes it works.
[quote=“AZJowett, post:127, topic:169756”]How To Set Up Vera3 with MiniMote DSA03202v1:
Now the scenes should show all the buttons assigned and the scenes with the scene #s. Be sure to click Save Changes.[/quote]
Thanks for writing this up. We bought a 3-pack on amazon. Setup was easy, thanks to the instructions above, and just loving these things! So far, working extremely reliably at a fair distance from our controller. I can easily see getting more of them. The only challenging part is watching everyone point them at the device they’re trying to control and not laughing
