how to use the status of a switch to use another switch
I have a switch that turn my lights outside on and of.
When the lights are turned on/off, another light must be turned on/off.
I created 2 scenes. 1 for on and 1 for off. In the advanced tab I select “when all devices in scene are properly set” and a delay of 1s.
When I turn on my light with Vera of SQ remote, the other light response accoordingly, but when I use the inwall switch, de light turns on after 5-10 minutes.
I poll this device every second.
What is going wrong?
I do a similar thing for my hall lights. two lights, two (3 way, ttl of 4 paddles) switches.
On Scene: event light A is turned on
event light B is turned on
 (you can enter multiple events in a scene, these are 'OR' conditions...either will trigger)
Command: turn A on
turn B on
This works almost instantly, with the exception of the slave switch on GE 3 ways…there’s a poll delay of up to 20 seconds on these.
Possibly nothing. If the switches don’t report status to Vera, the status updates will rely on polling. It can take a while and takes longer as your network grows.
That would be a really high rate. Did you use code to do that? Through the normal UI settings, you can't control the actual poll rate per device. Poll settings are [url=http://wiki.micasaverde.com/index.php/Polling_Settings]explained here[/url].
[quote=“Intrepid, post:2, topic:168760”]I do a similar thing for my hall lights. two lights, two (3 way, ttl of 4 paddles) switches.
Command: turn A on
turn B on
This works almost instantly, with the exception of the slave switch on GE 3 ways…there’s a poll delay of up to 20 seconds on these.[/quote]
Thanks for the support.
I created the scene as you said, but it does not work. When I turn on switch A by pushing it, switch B stays off.
When I put the switch on by Vera or SQ, it works in a second.
I set the poll to default.
For your information. I use a switch from Duwi.
What’s the exact model number / do you have a link to the manual?
I don’t think you’re doing anything wrong.
That would be a really high rate. Did you use code to do that? Through the normal UI settings, you can't control the actual poll rate per device. Poll settings are [url=http://wiki.micasaverde.com/index.php/Polling_Settings]explained here[/url].[/quote]
Thx.
I noticed, that the status of the switch does not come back to vera. When I put the switch on, and than poll the device in Vera, everything works.
I set the poll setting standard as described in your link and set the poll in the device to 5 sec., but no response, only after a long period op time.
Can I use an other setting, to get the status of my device sooner?
What you can set per device is the maximum rate, not the actual rate.
Say you have 12 switches like this, and you changed the poll rate ([tt]Z-Wave device > Options[/tt]) to poll every 5 seconds, instead of the default 30, it could still take a minute or more, or so, to get the status.
I don't think so.
I don’t think you’re doing anything wrong.[/quote]
Duwi 05431 Flush-mount Z-Wave switch (www.duewi.de)
Thanks. It does seem, implicitly, that the status of the device is retrieved through polling.
To be sure, can you post the [tt]Capabilities[/tt] form the [tt]Settings[/tt] tab of the device?
To be sure, can you post the [tt]Capabilities[/tt] form the [tt]Settings[/tt] tab of the device?[/quote]
Device #26
Automatically configure learn more
Variables
explain these settings
ID 34
Poll this node at most once every seconds (0=never poll, blank=default).
Energy used (explain this)
Capabilities 210,156,0,4,16,1,L,R,B,RS,|37,39,114,117,130,133,134,135,
Version 6,2,51,1,0
Manufacturer Duewi
Model
Neighbors 1,3,4,6,9,12,19,20,24,26,27,31,45,46,
Configured at 22-JUL-2011 19:9
Try running a full heal with stress test. This has fixed the same problem I have had. After I ran it my other switch has a delay of only 1 second. Good luck :slight_smile:
I have a couple of these switches, and they only support status polling, so there will always be a delay until Vera feels like doing a poll. A workaround is to push the switch 3 times within 1.5 seconds (just like when first setting it up); when you do that it will send its status to Vera right away.
By the way, the newer Duewi wall switches (type 06431, with a round green sticker on them) support status push, meaning they will report to Vera right away whenever their status changes. I just got some in the mail, and they work great: when using the switch, the associated scenario is triggered within 1 second.
