http://your_vera_ip:3480/data_request?id=update_plugin&Plugin=3008 does the trick. the last number is the plugin number. As garrettwp said, you should look a little bit further.
Sorry for that. I tried to look under Remote Control–>VeraAlerts, but the only one related I saw is “MOVED: Howto Upgrade the Vera Alerts Plugin” and the post mentioned “This topic has been moved to the VeraAlerts Plugin section.”.
I did not know there is actually another session that is for this. Sorry for my stupidness.
Thanks for the help.
