how to unregister a variable_watch callback
We are using variable_watch to register a callback with LUUP interface and get a notification when the variable changed.
This is working fine.
But we have a concern when we re-register the same variable with the LUUP for the same “function”.
Lets say we have a function [font=courier]handleVariableChange[/font]
and we have a Security sensor whose variable “Armed” has been registered with this handleVariableChange function…
[font=courier]luup.variable_watch(“handleVariableChange”, “urn:micasaverde-com:serviceId:SecuritySensor1”, “Armed”, device_id_of_security_sensor)[/font]
Now, when the code is restarted, we would automatically call the luup.variable_watch function once again…
And now if the variable changes, we get 2 call backs to the same function…
If we restart code once more (i.e register once more for variable_watch function… We get one more callback (i.e the same function gets called 3 times).
We want to avoid this…
Will the variable_watch function be fixed to not register a duplicate callback for the same function/schema/variable/device_id combination.
Is there a way to un-register this callback that was issued to variable_watch, and calling this function will remove the callback that is currently registered…
Any suggestions please…
Thanks in advance…
I’ve never heard of any fixes to the Luup Lua extensions. The following Luup Lua extensions are defective:
[ul][li]luup.timezone[/li]
[li]luup.blacklistip[/li]
[li]luup.device_supports_service[/li]
[li]luup.sleep[/li][/ul]
… and there is no Luup method to un-watch/remove a variable, Luup timers don’t support UTC, …
So I’m afraid you’re on your own. You could write a wrapper for [tt]luup.variable_watch[/tt] that makes sure that [tt]luup.variable_watch[/tt] doesn’t get called twice with the same set of parameters.
AFAIK watching a variable doesn’t survive a LuaUPnP restart/reboot.
