Yes, I am experimenting with higher values (like 130) in that setting to try to reduce z-wave messages during peak periods…
Neither spacing out z-wave actions by 1 second nor reducing polling impacted the frequent restarts. Even disabling polling didn’t help.
Of course I am frustrated, but before I ask anyone else for advice or to review logs, I am going to bite the bullet and do a factory reset and manually rebuild the configuration. It will not be fun - not just the re-including of z-wave devices and relearning of EnOcean devices, but also the configuration of the plug-ins and the cut-and-pasting of my three PLEGs. It will take a full day I estimate, but my wife is out of town this coming weekend so that will be a good time to get it done uninterrupted…
Unfortunately, after spending most of 3 days rebuilding my UI5 Vera3 post a factory reset, the problem has returned.
If two PLEG triggers happen at essentially the same time, each kicking off separate z-wave jobs, then often those jobs deadlock and Vera restarts.
I am trying to decide what to try next… I think I will start a new thread under PLEG sub-forum. Honestly, not sure it is really PLEG issue, but using PLEG is certainly where users would run into it…
