How to specify timeout on a socket request
I have the following LUA script in an event:
local socket = require(“socket”)
host = “192.168.0.3”
client = assert(socket.connect(host, 5150))
client:send("@movie\r")
client:close()
This sends text to a node.js script which I have running on a PC at that address (just a TCP server).
All works OK when that server is on, but when I turn it off the LUA script waits for about a minute before it continues with the other actions (such as turning lights one).
It is obviously pending a timeout.
What I’d like to do is to set the timeout to about 3 seconds so that it gives up quickly if the server/PC isnt on but I cant find out how to set it.
The doc will help:
http://w3.impa.br/~diego/software/luasocket/tcp.html
Thanks for that.
I have tried many different permutations and it still waits for about 3 mins if the server isnt on with this code:
local socket = require("socket")
host = "192.168.0.3"
local client = socket.connect(host, 5150)
if (client == "nil" or client == nil) then
  luup.log("Connection to pc failed")
else
  luup.log("Connection to PC OK")
   client:settimeout(3)
   client:close()
I have also tried this:
client:close()
although with that I would guess the client object isnt set so would probably throw an error when trying to use it.
I wonder if the timeout is occuring on the initial socket.connect which my setting on the client wouldnt affect but I have no idea how to set the timeout on that.
Anbody any ideas?
You need to used socket.tcp to get the handle, then set the timeout on it, then do a connect on the resulting handle.
There are a few examples on the web if you search for “luasocket timeout”
Great thanks.
This now works for when the server is either running or is not without any delays:
local tcp = assert(socket.tcp())
if( tcp ~= "nil" and tcp ~= nill) then
  tcp:settimeout(1)
  tcp:connect(host, 5150)
  tcp:send("@movie\r")
  tcp:close()
Thanks for your help!
