Whenever I open up Automator I get a first screen where it says connecting (directly or via mios.com) and then asks me to choose the gateway. Is there anyway to skip the screen if there’s only a single gateway present?
There is not currently a way to skip the screen if the iOS device stops the application after you switch to another (common if you have used a bunch of other apps or have elapsed some time since using Automator). It’s a good idea and one I will add to the list.
Thanks a bunch ![]()
No worries, it is a great idea. I have a ton of UI improvements in the work, in the “fabled” 2.0 release. This release is still far off so I am more and more thinking I should pull some of these commonly requested improvements into a 1.5 release to get them out sooner. I’ll do my best!
I just want to mention that I use Automator a LOT! Besides the basic device control, the reporting functions are amazing, especially when you dig around a bit. I especially like watching what Vera is doing when I am configuring it.
Keep up the great work!
