First timer on the forum and newbie vera user. Hello everyone and thanks for the great info.
I just installed my vera and I purchased a DSC TL-150 board. I had troubles and changes interface to 3DS and the LUA problem went away. My only issue is arm and disarm. They dont work. Vera says remote arm is not enabled. I changed the variable in the advanced tab to disarm and it still does not work. What or where should my next step be?
I had the device type set to 3DS. When I changed variables it says has to be IT100 or 2DS. I set it to 2DS and I get the Lua failure. So it doesnt work at all. Does it matter that I have 2 door zones or are there other variables i should change? the DSC TL-150 board instead of the EVL shouldnt be a problem?
[quote=“PurdueGuy, post:7, topic:173874”]Oops…my apologies! When I read “I had troubles and changes interface to 3DS” I assumed you meant you changed the physical interface…my bad![/quote]You are not alone, I also read it this way to start with as it was a bit ambiguous
@pricebn The IT150 is most likely quite similar to the earlier model Envisalink IP100 that didn’t have the 3rd party interface that the 2DS/EVL3 have and that the plugin uses.
If you are up to the task of writing a plugin, a previous user of the IP100 wrote a plugin for it that you might be able to adapt for the TL150, since it just uses the HTTP interface also:
Thanks. I just tried that and it uploads the files and I create the device but it does not create the partition or zones. I am UI5 and this might only be for UI4???
