How to Send configuration paramters to ZIR000 WALL MOUNTED SENSOR
Could anyone tell me how to send changes in configuration parameters to a ZIR000 WALL MOUNTED SENSOR?
The documentation says the following:
To change the mode of operation:
For Lighting Mode: Send a value of 0 to Configuration Parameter #17.
For Alarm Mode: Send a value of 1 to Configuration Parameter #17.
For Sensor Mode: Send a value of 2 to Configuration Parameter # 17.
Refer to your controller instructions on how to set Configuration parameters.
I don’t see this in the advanced screen of the device in Vera.
Thanks.
Here is the config pages from the ZTH100 Controller:
