cw-kid
1
Hi
Can anyone help? I can’t seem to see how to create this type of scene(s).
VeraLite UI5 / Fibaro Motion Sensor.
What I’d like: If motion is detected in the hall-way between 6 and 8am, turn on the light.
In the schedule tab there is no option to specify a time range like from 6-8am.
Can this be done with the standard VERA scene editor?
I am not using PLEG at the moment, so far I’ve not needed too.
Many Thanks
cw-kid
3
Hi
Thanks for the reply.
I see you have a Time Period
http://forum.micasaverde.com/index.php/topic,18679.msg141962.html#msg141962
Will have a look at that.
Cheers
cw-kid
4
Many thanks
That seems to work OK.
Will test a bit more but so far it seems to do the job fine.
Cheers
nullx8
5
Just arm/disarm it at the times you need it and set the trigger on “armed device”
