How to remove Startup LUA code?
Hi
I added some code in to the Edit Startup LUA box and now I can’t remove it. I tried deleting the code and pressing the code button but it doesn’t work and says Please fill required fields.
What to do?
Have you tried just a blank line, or just a comment line like this?
I delete the code and then pressed the spacebar once, I was then able to press the Go button and it saved. So hopefully that worked.
