How to Pan/Tilt/Zoom camera?
Can anybody help with how to pan/tilt a camera with ImperiHome? I have a Vera VistaCam PT (it essentially is an Apexis APM-J011-WS OEM for Vera), I can view it perfectly in ImperiHome, but I could not find any control for pan/tilt or preset positions.
Anybody?
I brought this issue to the attention of Evertygo. They were really fast in responding. Here is their answer for anyone interested in:
Thanks a lot for your quick response and valuable information.
Using your json data, we are doing a quick-implementation of vistacam
PT, which should be available in the next app upgrade on the play store.
The ImperiHome Team
The upgrade has been rolled out including this improvement : can you confirm if it works for you ?
Best regards,
I can get my camera to pan and tilt using my finger with a screen sliding gesture.
I am not sure if this is a glitch but if I slide my finger from left to right, the screen says"Camera move: right" and the camera does indeed move right the direction of my movement, and vise versa.
You would think that the up/down movements would be the same. But it is backwards. If I make a up to down movement, it goes and says up and down to up results in down movement??
Is this intentional?
