How to make scenes function even if Vera is powered down?
In designing scenes, is there a way to insure that they operate even if Vera is powered down?
It depends on how you define a scene…
Scenes are executed by vera, but associations between devices can function without vera. So you can associate a sensor with a light or alarm for example.
Try to find out wether you can do what you want with associations.
Just manually execute the Scene … Powerup Vera :slight_smile:
Simple answer - No, not from with in Vera itself. For Vera to fire off commands, it need to be powered on.
