Good day
I am using a Fibaro relay switch 2 x 1.5kw to control a gate motor via the Vera 3 home controller …
The system worked well up until a week ago and then … nothing…
I need to send the gate controller a pulse (off/on/off) … not a constant on state… any ideas…
The relay/switch is sending an “ON” state which opens the gate and half way through its opening cycle it stops… when I turn “off” the switch from vera the gate continues to open fully.
When I press to close the gate it closes fully with no problem.
I see I can change the configuration to allow the relay to turn off after a few seconds but the vera3 is not accepting the configuration changes…
I cannot change or add the variables. If I am correct the parameter 3 (automatic turning off relay after set time)needs to change to 3 (auto off enabled for both relays)from its default value of 0 (auto off disabled)and parameter 4 (time after which relay is turned off)needs to change to 5 from default value 20( 200ms)…
Am I correct or am I doing something wrong?
Any help will be appreciated.
