Sorry to post on an older thread but I’m hoping that someone can assist.
I’ve had my VeraLites for several years and just now decided to add some logging to them. Here’s where I’m at.
My Lite is on UI7 running 1.7.855
My DataMine 2 is at 1.914
My Lite is connected to another device via USB and I have a 16tb NAS on my desk. So I’d love to just point my DataMine over to it. That’s when I ran across this thread and started reading up.
I followed the steps at the beginning of this guide and everything worked fine.
If I manually mount my NAS with this command: mount -t cifs -o user=,pass=,nounix,noserverino //192.168.2.5/veradatamine /nas
I can see everything in the directory. So I know functionally everything is working. I also know that on a reboot this mount will drop.
So of course I went in to my DataMine device and under advanced/variables I setup all the options I needed to. Reading this thread some users, I guess, are on UI5 or older UI7 so the options are not all there but then some are.
Here are my questions.
So does this guide still apply to the firmwares I’m running on a Lite?
Do I have my options set correctly under my Variables tab?
If both of those are yes then there is something else causing my problem. As after rebooting my Vera the mount never occurs.
root@MiOS_35001409:/nas# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 4608 4608 0 100% /rom
tmpfs 31240 892 30348 3% /tmp
tmpfs 512 0 512 0% /dev
/dev/mtdblock7 11264 5976 5288 53% /overlay
overlayfs:/overlay 11264 5976 5288 53% /
/dev/mtdblock8 6144 6144 0 100% /mios
I?m not sure if the error in mounting is from DataMine bing ?uninitialised? for some reason or it?s not initialing because the mount is failing.
Here is the log:
-1-===========================================================================
09 10/22/16 22:51:07.463 JobHandler_LuaUPnP::Run device 149 DataMine room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 cat 0:-1 id parent 0/0x910d08 upnp: 0 plugin:8526 pnp:0 mac: ip: <0x2aeb2310>
50 10/22/16 22:51:21.838 luup_log:149: dataMine: Initialising dataMine System (1.914) <0x2b8f3680>
06 10/22/16 22:51:21.839 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: false #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b8f3680>
06 10/22/16 22:51:21.840 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xa6be48/NONE duplicate:1 <0x2b8f3680>
06 10/22/16 22:51:21.841 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b8f3680>
50 10/22/16 22:51:21.871 luup_log:149: dataMine: Error opening tmpfile during mountcheck <0x2b8f3680>
06 10/22/16 22:51:21.871 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountLocatione[0m was: now: #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b8f3680>
06 10/22/16 22:51:21.872 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountTypee[0m was: now: #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b8f3680>
50 10/22/16 22:51:21.923 luup_log:149: dataMine: Mounting dataMine storage (//192.168.2.5/veradatamine) to (
/nas/
/) <0x2b8f3680>50 10/22/16 22:51:21.978 luup_log:149: dataMine: mount command output:‘’ <0x2b8f3680>
50 10/22/16 22:51:22.011 luup_log:149: dataMine: Error opening tmpfile during mountcheck <0x2b8f3680>
06 10/22/16 22:51:22.012 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountLocatione[0m was: now: #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b8f3680>
06 10/22/16 22:51:22.012 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountTypee[0m was: now: #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b8f3680>
50 10/22/16 22:51:22.062 luup_log:149: dataMine: Mount point error: :://192.168.2.5/veradatamine <0x2b8f3680>
06 10/22/16 22:51:22.062 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: false now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b8f3680>
50 10/22/16 22:51:22.117 luup_log:149: dataMine: ERROR: Startup state is ‘uninitialised’! <0x2b8f3680>
06 10/22/16 22:51:22.118 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xa6be48/NONE duplicate:1 <0x2b8f3680>
06 10/22/16 22:51:22.119 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b8f3680>
50 10/22/16 22:51:22.119 luup_log:149: dataMine: Reinitialising configuration structure <0x2b8f3680>
50 10/22/16 22:51:22.121 luup_log:149: dataMine: Startup complete <0x2b8f3680>
01 10/22/16 22:51:37.166 e[31;1mLuaInterface::CallFunction_Timer-5 function deferredStartup failed [string “-- dataMine Plugin for Vera…”]:863: field ‘day’ missing in date tablee[0m <0x2d6f3680>
06 10/22/16 22:54:37.552 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetDataDirectorye[0m was:
/nas/
now:/nas/
#hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2f6f3680>06 10/22/16 23:05:59.739 Device_Variable::m_szValue_set device: 149 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountOptionse[0m was:
now:-t cifs -o user=,pass=,nounix,noserverino
#hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2eef3680>-2-===========================================================================
-3-===========================================================================
rootfs on / type rootfs (rw)
/dev/root on /rom type squashfs (ro,relatime)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,noatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,noatime,mode=600)
/dev/mtdblock7 on /overlay type jffs2 (rw,noatime)
overlayfs:/overlay on / type overlayfs (rw,noatime,lowerdir=/,upperdir=/overlay)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
/dev/mtdblock8 on /mios type squashfs (ro,relatime)
none on /proc/bus/usb type usbfs (rw,relatime)
-4-===========================================================================
Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn’t contain a valid partition table
-5-===========================================================================
SetDataDirectory-
/nas/
SetMountUUID -
SetMountPoint -//192.168.2.5/veradatamine
SetManualMount -0
-6-===========================================================================
{“dbVersion”:2,“Events”:{“count”:0,“last”:0},“Version”:“1.914”,“Variables”:[],“Graphs”:[],“guiConfig”:[],“nextId”:1}
-7-===========================================================================
