Thanks for looking that up, I ended up finding that same thread last night and following it through. I also added full read/wright attributes for the web files and it works. I’m relying on Google translate for now but I was able to setup a page and get it working. Pretty cool!
I also purchased a floorplanner .com account to get some nice 3D renders. Only problem is that it becomes next to unusable once you start adding a ton of 3d objects but it worked out.
I suggest you add a 110 outlet as an available asset, there are many other options I haven’t looked at in the config due to the lack of translation, but this is a solid GUI.
Hello,
I am the author of MyVera. I am French and my English is not very good…
I spent quite a lot of time to improve this interface and I think that the version of March 17th can be considered as the first stable version.
MyVera is, at the moment, only in French but it can be now translated. It is necessary for this to translate the text of the file resources\locales\lang.json. Chixxi proposed it. If this offer always hold, he is welcome.
Some precision on MyVera.
I use it on my iPad and my iPhone but several users have put it on Android (Nexus or other one). Dolphin seems to be a good solution under Android (because it accepts the mode full screen).
And for Chixxi, yes, VirtualSwitch and the VariableContainer are supported (I use them)…
[quote=“sb_domo, post:25, topic:173842”]Hello,
And for Chixxi, yes, VirtualSwitch and the VariableContainer are supported (I use them)…[/quote]
Thank you for the reply, I did notice that when looking at the new version and that made translating to english super easy. This version works great so far, and is one of the best interfaces I have used so far for Vera. Keep up the great work!
I’ve got this working. Thanks for the tips so far. I need to put curl in also.
Ive got this running on a windows machine for now
I have 2 issues so far:
in modules i cant scroll down to see the rest of the modules. This is in chrome. In firefox and IE, i get no interface to login.
after adding a module, it says to make sure you save. How do you save? theres no save button.
Hello,
MyVera works with Chrome and Safari but not with IE and Firefox because it use webkit.
By default, MyVera is for touch-screen, also you have to slide with the mouse to scroll.
To save the list of devices, you must go to the first screen with the back button (in MyVera, at the top, left), you will see a save button in red…
I haven’t got my vera lite yet so i tried to install myVera on my pc just to test it out. But i can’t figure out how i should install it. Or is it not possible to install on a regular PC just to test it?
You can install MyVera on a PC but you can’t test it without a Vera : The first thing MyVera do is running a synchro with the Vera. Without this, MyVera do nothing.
Ok, i got my Vera lite now. Bur could someone make a bit more dummie - friendly. Feel lika an idiot that dont understand how to install latest myvera on a usb.
i’m having a lot of problems… i finally managed to install MyVera on a USB i think.
But every time i tris to do something it asks me for usernam and password.
I keep typing the right ones and it keeps asking.
What am i doing wrong? Is there some other password? Can i turn the password thing of?
It’s really annoying not being able to do ANYTHING at all… !!
Hi
Is it possible to change the language for the compact version (i.e. directly on vera) of MyVera? I can’t seem to find the lang files or even the locales folder for that matter.
Also, if i wanted to uninstall MyVera would it suffice to delete the myvera folder on the veralite’s flash memory or is there some other procedure?
[quote=“jolerius, post:36, topic:173842”]i’m having a lot of problems… i finally managed to install MyVera on a USB i think.
It’s really annoying not being able to do ANYTHING at all… !! :([/quote]
On Vera, you can’t use htaccess protect I think. With MyVera, you can use another protection with a proxy (the pages for that are in protect directory*).
But, you should do your test without any protection to begin. In that case, you have to put a username and a password in the config panel but you can put anything…
*see config.html file (and username/password will be in _parameters.php).
[quote=“luissalvador, post:37, topic:173842”]Hi
Is it possible to change the language for the compact version (i.e. directly on vera) of MyVera? I can’t seem to find the lang files or even the locales folder for that matter.[/quote]
You have to use the new version of MyVera.
When you click on that button, You would see your view and you have to click on it where you want to put your module.
