How to install Mertik Maxitrol G6R-H4T1
Hi!
Hope this is the right section to post this one.
I try to get my Mertik Maxitrol G6R-H4T1 remote for the Dru fireplace working in my Vera. in the RFXmngr I’m able to send commands to the fireplace, but when I connect the RFXtrx433 to the Vera, no new device shows up when sending a signal with the remote (led’s are blinking on the tranceiver). Rebooted the system with no luck. Version: v180 / alpha 6. Anyone any ideas?
Thanks.
Solved this one by upgrading to alpha 7.
Temp + and - return a meesage ‘No implementation’. Anyone some experience with that?
Hello
I have the same problem, did you get to solve it?
Mine does not create the device and LEDs do blink
Thanks !
