How to insert a Everspring SP103 into a z-wave network?
Hello, I know that the battery devices doesn’t act as a repeater. But I don’t succeed in using the SP103 after a second device beside Vera. In other words I cannot use SP103 other than directly connected to Vera, as if it was not able to connect himself with other devices wh act as a repeaters and close to it.
My network is: Vera → 20 meters → WallPlug → 20 meters → SP103
→ 20 meters → AEON Switch
In the above network, the AEON Switch speaks correctly with the WallPlug who speaks correctly to Vera, establishing a real network. Instead, the SP103 doesn’t speak to AEON Switch. In fact it speaks only to Vera if it is in a close range.
Could someone help me, please?
Have you looked into using Aeotec?s new repeater and range extender?
An idea…
With the SP103 in its required location have you run ‘update neighbours’ under settings or carried out a system heal yet ? Doing this will help Vera work out the path/route available to it.
being a battery device, you will need to do your best to keep the device ‘awake’ while you run either.
Ok, Thank you for your idea. On this SP103 I have to do some more “experiments”. I’ll let you know ASAP the results.
