How to get z-wave dongle blinking?
Hi
After having copied my HomePro controller to Vera while the dongle stayed on the back of the vera box, everything worked OK. I got all my devices and can now control them. However, I wanted to add an extra HomePro device so I follow the instructions: remove the stick and push the key breifly and it should start blinking? But it does not, it stays off. When I touch it, it comes on for a few seconds and goes off again? It only blinks when in the back of the box?
I have formware 616 and the box is new with (I think) the updatable stick! Any helpers on this?
Solved - I had to reset the network and the stick chip then the stick worked! But I then lost all my devices and had to pair them all with the stick >:(
Obviosly copying the ACT controller to start with is not a good solution.
Another question: How do I see that I have the new updatable Aeon-stick?
Hi Sten,
You have the DSA-02203, this is the new fw-upgradable z-stick from Aeon-Labs, put it in the box myself :wink:
Hmm… sounds intriguing…
That it does, is that the dongle that should be shipping with Vera now? It’s not the one I just got last week.
